Starter solenoids
Generally a solenoid mounted on the starter motor itself to engage the starter gear to the ring gear on the flywheel, and a remote mounted heavyduty relay,sometimes called a solenoid, to supply electricity to the motor.
Not thread jacking but since this is about starters i would like to share a experiance i had with mine. The truck would start hard all the time and eventuly the truck would not start and the starter would just spin so i though the starter was shot but it turned out to be the starter bolts were really loose and the starter was not lined up with the teeth on the flywheel so i just tightened them and it fixed it
I inspected the flywheel ring gear and it looked fine, all the teeth were intact and looked great. It was a reaL hassle because it happend when i was in a store parking so i went under there and thats when i noticed the starter loose but you can tell when its getting loose. It makes a pretty good banging sound.
klein444
Jun 20, 2015 11:48 PM
nevadagramm
Oct 17, 2014 07:59 PM
thunderball52
Oct 6, 2014 08:08 PM
