6.7 Valve adjustment
Old Mar 20, 2012 | 08:30 AM
CrazyLadysHubby's Avatar
Default 6.7 Valve adjustment
How often should the valves be adjusted on a 6.7 Im almost to 150k some have said every 80k.
Old May 4, 2012 | 08:11 AM
Andy-Custom Diesel's Avatar
FormerVendor
Cummins claims that these engines are designed to run their lifetime without valve lash adjustment. I personally recommend adjustment at 100k intervals. With 150k on it, if you check them they will be off slightly.
Old May 4, 2012 | 10:39 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
always a good idea.
Old May 4, 2012 | 05:53 PM
coors_man_2005's Avatar
Any one have the order you can do them in? As in like what valves with # 1 cylinder tdc and so on. thanks
Old May 4, 2012 | 07:03 PM
FormerVendor
With #1 piston at tdc compression adjust intake valves on cyls. 1,2, and 4 and exhraust valves on 1,3, and 5. Rotate engine 360° til #6 is at tdc compression and adjust intake valves on cyls. 3,5 and 6. Exhaust valves on 2,4 and 6.
Old May 4, 2012 | 09:12 PM
Thanks. thats some good info to have appretiate It .
Old May 4, 2012 | 09:25 PM
FormerVendor
No problem...anytime
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
woodsman27
Oct 26, 2014 02:13 AM
