need help asap
Old Mar 18, 2012 | 07:05 AM
FORD-INTERNATIONAL MAN's Avatar
Default need help asap
ok i have this really bad fuel leak that started one day coming from under the snap plug from the fuel heater.. couldnt stop it. jb weld fixed that.. all put back together and started it up ....leaks out of the fuel heater o-ring now.......WTF.....so next i take it back out look at it for a couple days and decide F it just gunna go and jb weld the rest of it so i get it up in there nice and tight and jb weld the plug and heater element around the oring on top of the fuel filter assembly so no matter what fuel does not by pass up threw that....thought i fixed it butg i was wrong now leaks out around fuel filter and and is dripping fuel on my manifold..then i thought that turning the fuel pump back to stock would fix the problom...did that and started it and it was fine for ehhhhhh3 minutes and started leaking again......weird thing is i my motor was hot that if i shut it off and waited 10 15 minutes no more than that that i would turn the key fire right up then skip and pop and eventually shut off....there id go cranking and cranking till id fire back up and it would take a good 2 minutes.....bullllllshhhiiiiitttttttt! im tired of this and i reallllly need help.im ready to burn my 7.3..if you can help me please right back or if u need any pictures of the problem im having let me know
Old Mar 18, 2012 | 09:40 AM
blacksmokeaintbroke's Avatar
sorry i cant help never had that problem,but i get the same way when my 7.3 is acting up,sometimes the best thing todo is to walkaway,and cool down.i have been known to throw a wrench threw a window or two.evertime i get the fuel return line leaking and i put on a new set i get the same way,sometimes its a 15 min job or 2 or 3 days.goodluck.
Old Mar 18, 2012 | 11:38 AM
cowboyford16's Avatar
Take it apart and replace the o rings they are 20 something years old and brittle common problem
Old Mar 19, 2012 | 07:42 PM
but i did twice....or are you talking about the pump...it was leaking out air realease valve thing that looks like a valve gut.all i did was put a metal valve cap....seemed to fixed problom but keeps running out of fuel after i shut it off.:arg h: ughh im getting aggrivated
Old Mar 29, 2012 | 11:45 AM
4x4manonbroke's Avatar
I would X out the fuel heater all together..... or get a new one thats in-line or something.... I wish you could post some pic's so we might be able to help more... sorry dont have anything else to suggest...
Old Mar 29, 2012 | 08:26 PM
ill get some pics up tomorrow...maybe even a video but it will be on youtube.yeah ill do that ill put up a video of it running then shut it off for 15 mins and fire it back up
Old Apr 2, 2012 | 09:50 PM
Sweet... yeah post the link if you can if not then just let me know the title of the viedo and user nam,e and i will do what I can to help ya out...
Old Apr 18, 2012 | 03:48 PM
Well idk what i did but it stoped leaking. Sorry i didnt reply back my enternet went down
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
jeremiah1
Jun 21, 2015 06:45 AM
canigeta727
Mar 18, 2015 05:00 PM
yfzrunner
Feb 7, 2015 10:52 PM
