How to do Alignment at home
Old Mar 17, 2012 | 08:32 PM
oct6454's Avatar
Default How to do Alignment at home
Hey, just replaced my tie rods today and now my alignment is way out of wack. Looking for some tips on how to re align it enough to be fairly driveable.
Thanks, Oliver
Old Mar 17, 2012 | 08:37 PM
2500HeavyDuty's Avatar
if you just did the tie rods you can adjust the toe and use a tape measure to measure the distance between a reference point in the tread on the front of the steer tires and the back of the steer tires, a little tow in is ok. but not so much and eyeball it straight helps too.
Old Mar 17, 2012 | 08:58 PM
oct6454's Avatar
Okay thats what i had in mind. Thanks for your advice!
Old Mar 17, 2012 | 09:39 PM
Eddiebuntain's Avatar
You'll want about 1/32"-1/16" toe in, measured as close to halfway up the front and rear of the tire as possible. Front wheel drives might require slight toe out to allow the tires to straighten out under power.
Old Mar 19, 2012 | 10:18 PM
Truno223's Avatar
A trick I use to find a center point on the tires is to put the front end in the air on jackstands, then spin the tires and hit them with chalk to get a nice round line.
Old Mar 20, 2012 | 09:43 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Yup, a tape measure will do the trick. As stated above toe it in just a tad
Old Apr 8, 2012 | 01:35 PM
s10driver85's Avatar
i just did all my tie rods, got pretty close. on the alignment rack i was only .45 degrees off. felt good about that. measured the tires front and back, marked measure points, then measured center to center on rod ends and duplicate with new hard ware. don't be cheap spend the 100 bucks to save your tires. go to your local alignment shop
Old Apr 9, 2012 | 02:50 PM
1AMatt's Avatar
Yep that would be your best bet! They will get it exact
Old Apr 9, 2012 | 02:56 PM
A/Ox4's Avatar
Many shops offer free alignment cheeky. I get mine checked every 6 months. Then it's only $50 to correct if I want to.
Sent from my iPhone
autostroker
Jul 4, 2015 10:39 AM
ramrunner01
Apr 27, 2015 12:01 PM
gunman41mag
The Sportsmen's Lounge
Mar 16, 2015 07:43 PM
ajwright64
Feb 17, 2015 10:08 AM
