6.5 keeps shutting off any help?
Old Mar 16, 2012 | 11:28 AM
cumminsfreak5.9's Avatar
Default 6.5 keeps shutting off any help?
i just got a 98 3500 with the 6.5 td in it ,and it keeps stalling and sometimes it will start back and other times i have to wait a few mins,i tried replacing the in frame fuel pump that didnt seem to help, i heard people saying it was the pmd but i wanted to make sure before i spent that kinda money on it any help would be greatly appreciated thanx...
Old Mar 16, 2012 | 12:46 PM
ebarresi5894's Avatar
sounds like a pmd.
if you have another one or have a friend with a good that is the only way to test it
Old Mar 16, 2012 | 01:02 PM
great white's Avatar
DTC codes first please.
The Pump driver is a very likely culprit in a ds4 truck where it just dies for no reason.
While there is no OBDII code specific to the PMD failure, there are codes that associated with it when it fails. Kinda like a cascade failure effect...
Old Mar 17, 2012 | 02:56 AM
Norway's Avatar
I have the same problem with my 6,5 td Tahoe...could it be a "sticking metering valve"??
Old Mar 17, 2012 | 06:30 AM
Please start a new thread and give your year...
Old Mar 17, 2012 | 10:29 AM
x2 no hijacking!
Old Mar 18, 2012 | 10:23 AM
would a fuel filter cause this??
also something called a super boost sensor when plugged in the actron obdll tester
Last edited by cumminsfreak5.9; Mar 18, 2012 at 10:23 AM. Reason: Automerged Doublepost
Old Mar 18, 2012 | 03:26 PM
You mean the stalling for no reason?
Nope.
At least, not what you describe.
Super boost sensor?
Never heard of that one.
If you can wait a while, you can buy used pmd's on eBay for 30-40 bucks.
As with all things from eBay, you take your chances. But if you swap one in and your problems change or go away then you can spend the coin on a new one.
I'd recommend the kit from Heath diesel, but there are others out there....
Old Mar 18, 2012 | 05:28 PM
pmdcable.com has good deals too
Old Mar 22, 2012 | 11:40 AM
Blod's Avatar
got mine on ebay! workd great and for 60 sent to my door in 3 days you cant beat that, most r used but tested, anyway its a cheaper route!
Don
