6.5 no electric to gauges and fuses need help asap
Old Mar 14, 2012 | 07:37 PM
wrangling661's Avatar
Default 6.5 no electric to gauges and fuses need help asap
Need help I have no power to the IP, gauges, glow plugs, fuel sod. Checked the main fuse box all are working except the main three to run the motor. I've hit a brick wall out of ideas please help.
Old Mar 15, 2012 | 08:41 AM
ebarresi5894's Avatar
check your grounds, and replace the three that are blown
the glow plugs wont work if the eng-i fuse is blown too
Old Mar 15, 2012 | 10:28 AM
Checked all my grounds. Changed fuses and still nothing. Wondering if it could be the Ecu or the ignition switch?
Old Mar 15, 2012 | 10:57 AM
does it crank?
Old Mar 15, 2012 | 11:03 AM
It cranks. But can't get it to fire. I bulb checked all my connections and still no power to the IP or glow plugs and ecu1 and eng1.
Old Mar 15, 2012 | 01:12 PM
jrsavoie's Avatar
I'm assuming there is no Wait to Start Light?
I've had to replace the ignition switches on most of my 6.5 diesel vehicles, all of which had upwards of 200,000 miles on them.
I also had bad ignition switches blow fuses.
I would also add grounds. I add a ground to the passenger side battery box that continues down to the frame by the starter, I add a ground from the heater blower ground to the dash mount bolt inches away & a ground from the ground cable to the ground stud at the back of the engine.
I also use copper coat or other anti-seez or dialectric grease as appropriate.
