06 bad injector and accelerating on its own
Old Mar 12, 2012 | 07:17 PM
wyoranch's Avatar
Default 06 bad injector and accelerating on its own
I've got an 06 auto with 150k miles. Has a miss. Scanner says number 6 injector is bad. Odd thing is, once you get it past 1200 rpms and let off the gas it stays there and will shift through the gears all the way to 50 plus mph with foot off the gas. If you stop it tries to take off. Put it in neutral and it revs for a second then returns to normal idle. Ideas?
Old Mar 12, 2012 | 09:28 PM
s10driver85's Avatar
i think you answered your own question...
Old Mar 12, 2012 | 09:31 PM
wildbill's Avatar
Park the truck and replace the injector ASAP. Otherwise your looking at it sticking open and scoring a cylinder, along with a crankcase full of oil.
Old Mar 12, 2012 | 10:00 PM
tower_ofpower's Avatar
Crankcase is supposed to be full of oil diesel not so much
Old Mar 12, 2012 | 10:15 PM
good call
Old Mar 13, 2012 | 07:54 AM
wyoranch's Avatar
I am getting the injector replaced today but I didn't know a bad injector would cause it to do the other stuff
Old Mar 13, 2012 | 06:23 PM
wildbill's Avatar
What it was doing was over fueling that cylinder. BTW, meant to say crankcase full of fuel.
Old Mar 15, 2012 | 01:56 PM
wyoranch's Avatar
Yeah, new injector fixed the problem. Thanks for the help guys
Old Mar 15, 2012 | 02:24 PM
wildbill's Avatar
Cool.
Old Mar 15, 2012 | 02:27 PM
Eddiebuntain's Avatar
Crankcase on automotive applications should usually only have one or two gallons of oil. A crankcase FULL of oil ends bad.
