smarty???
Old Mar 9, 2012 | 07:34 PM
s10driver85's Avatar
Default smarty???
Ok, i think i have made up my mind on going with a smarty... but what is this stacking i hear about? does it help, make the truck more driveable, increase mileage, or whats the point? i hear alot about it. help please
Old Mar 12, 2012 | 03:06 PM
98dodgecummins's Avatar
I wouldnt stack anything it is really hard on a truck. just get a smarty and be done with it.
Old Mar 12, 2012 | 03:33 PM
H.R.D's Avatar
Stacking is used to squeeze every bit of electronic performance out of a motor. It is also used to even out the power band. Such as an edge juice fuels good from mid to high range while a smarty fuels good down low. So you combine the two to increase the hp level through out the power band.
A smarty should do just fine for what you want.
Old Mar 12, 2012 | 03:38 PM
I'd look at upgrading your injector nozzles.
Luke
Old Mar 12, 2012 | 09:34 PM
Luke
can i just do nozzles without doing the injectors, or do you do both? i see you have some 110 nozzles on your site for 5 and some change help me out.
Old Mar 12, 2012 | 09:51 PM
H.R.D's Avatar
Yes you can just do nozzles. They are fairly simple to change just need a vise and some wrenches. It is always good to have them flow checked before installing into truck but that option may not be available to you. The only reason to do so is to make sure everything is good with the bodies and new nozzles.
Old Mar 12, 2012 | 10:25 PM
what size would you think i can step up to before needed other fuel upgrades? or worry about EGT?
Old Mar 12, 2012 | 11:24 PM
Our 90hp nozzles work great with a stock cp3.
Luke
Old Mar 13, 2012 | 07:21 PM
right on i keep that in mind.
05cumminsCA
8
Feb 3, 2015 09:29 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
5.9sledhead
Price Quote - Request A Price
Oct 28, 2014 11:43 PM
