Boost pressure
Old Mar 9, 2012 | 01:26 PM
powerstroker13's Avatar
Default Boost pressure
How much boost pressure can my 97 7.3l engine handle?
Old Mar 9, 2012 | 01:45 PM
twinboys's Avatar
The boost pressure is insignificant compared to the pressure created when the fuel and air ignites.
Old Mar 9, 2012 | 04:42 PM
yes but once you start getting aftermarket turbos and such and higher boost pressure what will you need to upgrade to handle the extra boost? I must have been misled but i have been told that once you get to certain boost pressure you need to start upgrading your head studs and such?
Old Mar 9, 2012 | 05:12 PM
94turbostroker's Avatar
yes, the head gasket only will hold till a certain boost and it can hold over that but you risk the chance of blowing it
Old Mar 9, 2012 | 05:54 PM
fordornothing's Avatar
you can run around 40 psi with your typical 7.3.
Old Mar 9, 2012 | 07:30 PM
joebob3093's Avatar
Moderator
It will hold 100+ with the right mods
Old Mar 9, 2012 | 08:50 PM
thank you
What are the right mods? head studs?
Last edited by powerstroker13; Mar 9, 2012 at 08:50 PM. Reason: Automerged Doublepost
Old Mar 9, 2012 | 10:01 PM
twinboys's Avatar
Boost is only one ingredient to the stresses on the head bolts/studs. Your question could have been how much fuel will it handle and my response would be the same. Asking how much fuel makes more sense to me because that would indicate which injector to buy and therefore which turbo will match. A better question would be how how much pressure will those two ingredients create. i.e. power (or more accurately torque). There is a direct linear relationship between torque and the tension on a head fastener.
Example: ARP head stud rated at 220,000psi x .15 square inches per stud x 18 studs per head / 4 cylinders per head / 27.27 square inches per cylinder = 5,458 psi... of "boost"?
Old Mar 9, 2012 | 11:44 PM
joebob3093's Avatar
Moderator
Head studs, fire rings, bed plate, main studs. I probably forgetting stuff. Stock the engine can handle about 40psi. After that you need head studs or before depending on how you drive and how much insurance you want.
robbyS
Apr 16, 2015 02:22 PM
dango
Jan 22, 2015 04:23 PM
Tsgbk9
Dec 23, 2014 11:54 AM
cameronlee51
Oct 28, 2014 12:33 AM
GreenDieselF
Oct 20, 2014 02:05 PM
