Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Power Steering Flush, Do It Yourself
Old Feb 2, 2008 | 04:24 PM
RSWORDS's Avatar
AWESOME WRITE UP!!!!
Can you tell a differance? Was it acting up or justa preventative matainance thing?
Old Feb 2, 2008 | 04:38 PM
wildbill's Avatar
Preventive maintenance. Seemed a little bit smoother afterwards.
Old Feb 27, 2008 | 07:48 AM
asimpson's Avatar
I did all that. However, I am still having problems. Not sure if it is the power steering pump, or the steering gear box. Basically my problem is when I am driving straight down the road the wheel becomes tight. When I am turning at lower speeds, seems to be fine. I had a helper in the truck turning the wheel and while under the truck noticed the fluid going into the cooler seemed to come in bursts, or pulsate. I don't think there is any air in there, but I could be wrong. At least there are no air bubbles in the reservoir. Anyone know whats going on, or experience this before?
Old Feb 27, 2008 | 07:27 PM
wildbill's Avatar
How old a pump we got? Could be failing.
Old Feb 27, 2008 | 07:50 PM
asimpson's Avatar
I just replaced the pump. Still having the problem. Wondering if it could be an alignment issue? Either that or the hydraulic brake booster, or the power steering gear box.
Old Feb 27, 2008 | 07:59 PM
wildbill's Avatar
Never had a wheel get tight from being misaligned. Very well could be the steering box. How do the brakes work? Act like no power steering ate all?
Old Feb 28, 2008 | 09:49 AM
1Tondiesel's Avatar
I replaced my steering box (04 Ram) and the one I got from the parts store was bad from the get go. Finally ponied up the money and bought another from the dealer. The nice thing about the dealers is it comes with the reservoir attached so you don't have to mess with swapping it over to the new unit.
Old Mar 19, 2009 | 01:47 PM
dbowlds's Avatar
When you are flushing the fluid while pouring in new do you need to move the steering wheel back and forth to circulate the new fluid through the power steering rack? I'm assuming you also have the motor idling while doing this so the pump is being driven. Want to switch to Amsoil synthetic ATF for fluid. Have heard good things about it. Dealer wanted over $100 to flush power steering fluid. Sounds like a pretty easy job to do yourself. 2007 dodge 2500 5.9 Cummins, banks 6 gun power pack, bypass oil filtration Kore 3" life RBP wheels 35" Toyo MT's
Old Mar 19, 2009 | 03:25 PM
GRI's Avatar
GRI
Last I knew the pump had the resevoir attached?
Old Apr 13, 2009 | 09:21 PM
oglejust's Avatar
see anything wrong w/ this?
sounds like maybe your not getting enuff vacuum
