Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
ford touchpad entry
Old Feb 26, 2012 | 06:38 PM
hughesis21's Avatar
Default ford touchpad entry
Does anyone know if the ford trucks come with the touchpad keyless entry.. more specific. 2004 ford f250 lariat?
Old Feb 26, 2012 | 06:39 PM
03Powerstroke's Avatar
yes
Old Feb 26, 2012 | 06:55 PM
hughesis21's Avatar
I just bought this truck and the numbers were in he glovebox but they didn't unlock the doors.. is the pad battery operated or what should be my first step in fixing this?
Old Feb 26, 2012 | 06:57 PM
no clue, mine doesnt have it... but my friends 04 lariat has keyless entry
Old Feb 26, 2012 | 07:07 PM
hughesis21's Avatar
Im not talking about the key fob... im taking about the plastic pad w numbers mounted on the door.
Old Feb 26, 2012 | 09:08 PM
deck60's Avatar
i think you will find all the info you need here
Keyless Keypad Code - Ford Truck Enthusiasts Forums
look at post 9
Old Feb 27, 2012 | 08:19 AM
Mdub707's Avatar
When you touch it, do any of the numbers light up? If so, then it doesn't need replacing. Chances are the previous owner changed the passcode to their own personal code. You can bring it to Ford and have them read the code on it, or anyone with AutoEnginuity should be able to retrieve it too.
Old Feb 27, 2012 | 08:24 AM
RAW's Avatar
RAW
On my '05 and '06 F550 work trucks, both the factory code and code that I learned into it worked. I was surprised that the factory code worked after I learned my code into it, I thought it would only store one code.
Old Feb 27, 2012 | 09:11 AM
Mdub707's Avatar
Good point Ryan, never really thought about that since I've always just used the factory code, but now that you mention it I do remember reading that somewhere when programming a buddies.
If the numbers light up when you touch a button, it should work, if not, then it will need to be fixed. I don't know how the factory one's are wired up, but I'd imagine they're hard wired!?
You can get add-on ones from Ford that are battery operated and just stick on with double sided tape.
Old Feb 27, 2012 | 02:06 PM
gunman41mag's Avatar
Moderator
In my Lincoln, after you press the code, you hit another number on the pad & it would open the trunk, or rear doors
