ohm 9 pin to valve cover, not sure what to make of this
Old Feb 24, 2012 | 04:41 PM
Lucretus's Avatar
Rain ohm 9 pin to valve cover, not sure what to make of this
I was getting a SES light once and awhile and the truck would run rough. Once I lost power on the highway and had to pull her over. Stopped the engine and restarted, all was normal. I started reading up on the problem and decided to ohm the 9 pin connector and got OL at the injectors. I removed the valvel cover and saw that the other side was plugged in and it had fords clicp to locking in. I reseated the connector anyway and did the ohm test again and it read less that 5 ohm. Put her back together and started it up, ran GREAT for 1 minute and then SES light came on and ran way worst than before. Did the ohm thing again and they all over the place. Can I get some advice here please.
I'm getting lots of smoke now when I start it up. If I need parts can you tell me what I might need and were to get them at the best price?
Thanks alot guys
Old Feb 24, 2012 | 04:51 PM
95powersmoker's Avatar
Have you retrieved that code? I would get that..
Then I would order some new harnesses. Riffraff can get em.
Old Feb 24, 2012 | 04:53 PM
Lucretus's Avatar
No I have not. I didn't know where I could get that.
Need to hook the truck up to a scanner that can retrieve DTC's.
Old Feb 24, 2012 | 05:03 PM
Lucretus's Avatar
will this scanner do the job?
Equus 3130 Innova Diagnostic Code Scanner with Live, Record and Playback Data Capability for OBDII Vehicles
Old Feb 24, 2012 | 05:05 PM
My guess would be no. Looks like a generic scanner. Something like an aeroforce scan gauge or an edge/superchip programmer that reads dtc's would work also.
Old Feb 24, 2012 | 07:45 PM
gradyc's Avatar
Autoenginuity with the ford enhanced package is also an excellent scan tool for it. It works with a laptop.
Old Feb 25, 2012 | 04:25 PM
Lucretus's Avatar
I still don't have codes but might have it tomorrow.
I rechecked the ohms on the Injectors and they are all under 5 ohm, normal. I think I can rule out the wiring harness with that, right? I did notice that the female 9 pin connector had missing insulation near the plactic connector, on both sides. Could that be causing the problem? Also I did a light test on the female conector with the key turned on (with the wait to start light on) and the key off and could not get the light to come on the probe. I checked the probe on other things and the probe is working.
Thanks guys for sticking with me until I get the codes to you.
Old Feb 26, 2012 | 07:46 PM
Lucretus's Avatar
Default Put a code reader on today, no codes.
Had a friend put his code reader on it today and no codes. I know his code reader works because he uses it on his 7.3 and 6.0. Ohmed the drivers side and had all the injectors read 1.9 which sound odd that they all read the same but I did it 3 times.
I also changed the CPS, got it at Nappa for 25.00, no change in idle at all but I am able to get some RPM out of the pedle which wouldn't happen before.
Old Feb 27, 2012 | 08:51 PM
Lucretus's Avatar
Is there anyone out there can recomend next steps?
Thanks
