Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Single To Dual Rear Wheel Conversion
Old Jan 31, 2008 | 09:21 PM
jfoose's Avatar
Default Single To Dual Rear Wheel Conversion
I am in the process of helping my pop convert his single axle 2000 F250 to a dual rear wheel setup. His bed is rotting off as of recently and we are thinking about putting dual wheels on the back to stabilize the truck while towing. We will either have a custom bed made to fit the rear end, or find a used F350 bed to drop on the rear. My question is, who has done this already? Do we need to switch axles, or can we use adapters? what is the advantage and disadvantage of both? What is the best source for a replacement bed for the truck, and what years could we use? His truck is a short bed crew cab. He pulls a fifth wheel rv, that is not too large, about 11,000 to 13,000 loaded. Any information would help us out. Thanks.
Old Jan 31, 2008 | 09:52 PM
LOGANSTANFORTH's Avatar
just bolt the dually wheels to the factory axle and buy a bed to that width, and buy you a set of front dually outters and swap them.....
Old Jan 31, 2008 | 10:06 PM
BBD's Avatar
BBD
Check this site out tons of Dually conversion stuff:
http://www.chromewheel.com/index.html#i
BBD
Old Feb 1, 2008 | 12:43 AM
toy4xchris's Avatar
this would be the simplest way about it have you thought about possibly doing a flat bed on it?
Old Feb 1, 2008 | 07:12 AM
jfoose's Avatar
we have thought about putting an aluminum flat bed on. We don't know what the price difference would be. Would putting the dual wheels on require adapters, and are they as strong? thanks guys.
Old Feb 1, 2008 | 05:32 PM
you dont need adapters, they should bolt right on your factory studs.....my brother bolted a set of factory steel dually wheels on his 1989 F250, and its the same rear axle you have....just 1/4 inch bigger ring gear and different lug pattern.....but still the same.....
Old May 29, 2014 | 06:31 PM
timlinehan990's Avatar
so all i have to do is get dually rims and bolt them on to the factory studs no dually adapters needed?
John Sutton
Diesel Engine Conversions
Aug 24, 2015 04:12 PM
Ward_59
May 12, 2015 04:39 AM
2002cabandchassis
Oct 29, 2014 01:59 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
