Intercooler?
Old Feb 22, 2012 | 02:42 PM
powerstroker13's Avatar
Default Intercooler?
I have a 97 f350 and ive been looking into getting an intercooler but they are so damn expensive. Would i be able to pull an IC from a newer model truck from a junkyard or something? if so what year would work best?
Old Feb 22, 2012 | 03:44 PM
twinboys's Avatar
superduty 7.3 or the 6.0 is bigger.
Old Feb 22, 2012 | 04:18 PM
will the 6.0 cooler fit?
Old Feb 22, 2012 | 04:27 PM
twinboys's Avatar
It fits as well as the 7.3.
Old Feb 22, 2012 | 04:33 PM
so would i be better off getting the 7.3 or the 6.0?
Old Feb 22, 2012 | 06:23 PM
fordornothing's Avatar
well it's up to you. the 7.3 has aluminum end caps, and the 6.0 has plastic. (some say that the made a 6.0 IC with aluminum end caps. i don't think this is true.) you will need a spyder pipe from a early 99 superduty.
Old Feb 22, 2012 | 06:26 PM
DieselDanBoy's Avatar
spyder pipe? you mean the intake Y in the valley? I was going to ask the same question about which intercooler as well
Old Feb 22, 2012 | 06:56 PM
joebob3093's Avatar
Moderator
Most all 7.3 intercoolers had plastic ends. E99 were the only ones with metal ends I think. I'm running a plastic ended IC from an 01 and it works great. As far as I know all 6.0 IC had plastic ends but I wouldn't worry about that unless you plan on pushing 50+ psi
Old Feb 22, 2012 | 11:40 PM
95powersmoker's Avatar
No... My 2000 has metal ends... It's a mix in the 7.3 years...
Old Feb 23, 2012 | 02:07 AM
joebob3093's Avatar
Moderator
Thought it was mostly the early SD but guess not.
