HELP!!! bad running
Old Feb 20, 2012 | 11:32 AM
caddydaddy's Avatar
Default HELP!!! bad running
Hi all i have a 1992 6.2 non turbo chevy truck which is an 165 hp ex army vin number 1gbgc24j3pe155275 im really struggling to find whats the matter with it it starts fine but when driving it its really down on power, some time there seem to have extra power without moving the throttle then starts to run uneven and nearly cuts out or does cut out and stalls alot aswell , but starts up straight away. Has anyone had the same trouble or can any one HELP
ROY
Old Feb 20, 2012 | 10:18 PM
ebarresi5894's Avatar
whats it have for miles?
injectors could be bad
could be the sock in the tank
leaking fuel lines
bad fuel pump
need to do a little diag. to help you out a little more
Old Feb 21, 2012 | 10:48 AM
caddydaddy's Avatar
Default BAD RUNNING
Thank you for your reply
The truck has only 44000 miles.
No fuel leaks etc.
There is no lift pump on the o/s/f on the block as it has a blank plate.
There is a small electric pump which has two wires in the C section of the chassis near the tank.
I do not know want a sock in the tank is, please can someone tell me
Old Feb 21, 2012 | 05:20 PM
its pretty much the a filter on the end f the sending unit so it doesnt suck in crap.
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
1997fordf350
Jan 15, 2015 06:12 PM
carid
Jan 12, 2015 04:32 AM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
cmalson
Nov 29, 2014 12:57 PM
