Steering Wheel/ Key both LOCKED
Ok went outside this morning and key would not turn. Steering wheel is locked only moves about 1 inch either way. I have no idea how to get it unstuck. I checked all fuses and jacked the truck up in front and manually turned wheels. I rocked the truck back n forth. Nothing has worked. Is there a way to get this dumb thing started!! I need to get it moved ASAP!! Been out in the street for 3 hours and figured nothing out.
Thanks guys
Thanks guys
I did the whole wheel turn and nothing. Turned it both ways and turned key at the same time. Still locked. And is there a certain way of telling if the ignition switch is bad?
Yea sort of ... I mean ... im looking on autozones website and im seeing ignition lock cylinder, ignition switch, ignition switch connector, an ignition switch kit ...trying to figure out my best option. I suppose if it works it works. autozone has a decent return policy.
That all sounds like the same thing to me as an ignition switch, just with different titles....If those are specific parts within the switch itself, i would say it would be easier just to replace the whole switch and not just a component of it..
With the exception of the connector, all that sounds like is just the wiring harness that would be attached to the switch itself...You will need to check the switch to your old switch to see what setup you have. Most have 3 wire wiring harness that is attached to the switch itself
i know my 08 gets stuck with the wheel turned. i have had too put a lot of force on the wheel and turn the key. my wife could not do it one time when it was stuck. i hope this is your trouble. i hate to changes switches.
Pull the wheel hard left and kinda pinch it with your laft arm and chest and with left hand pull the shifter to left and turn key with right hand, don't ask me how I know this///well OK my wife had the truck and couldn't get it to turn, had to drive the Tonka Toy/explorer sport/ 30 miles to get her, she parked with wheels turned hard. Anytime I park I grab the wheel and rock it back and forth to make sure no tention on it. The shifter is the key/ no pun intendid
