EJWA-CTS Install Questions
Old Feb 18, 2012 | 07:53 AM
UglyTruck's Avatar
Default EJWA-CTS Install Questions
Hey Guys,
WELL! TODAY IS FINALLY THE DAY!
We only have till about 3 this afternoon because my wifes birthday party is tonight and I dont dare be late so we are only going to do the EDGE today and maybe the BHAF. we will do the injectors in a couple of weeks. which is good, I want to see what the edge does by itsef, then see what the difference is with the new injectors.
We finally have time to take the truck into a buddies shop today and they have no weekend work scheduled in the diesel shop or the trailer shop so we have the whole place to ourselves.
I have a couple of questions before we do.
Obviously I need to reflash it with th hypertech programmer to return it to stock before we start, but should I also remove the B&D diesel boost fooler? I installed it because it kept throwing an overboost code with the Hypertech and going into limp mode. will it still need the fooler with the Edge or it that issue compensated for within the edge programmer?
Thanks Guys.
Old Feb 18, 2012 | 09:49 AM
diesel life's Avatar
the ejwa already has a boost fooler built into it... i like mine it was a niticable power gain definantly..... im wanting injectors also what size are you going with???? need a tranny first though when i put my juice in she started slippin
Old Feb 18, 2012 | 05:51 PM
UglyTruck's Avatar
I went with 100HP "big Dawg" Injectors from Luke at Diesel Dawgs. he shot me a pretty great deal on injectors, the EJWA-CTS, Stealth plate, Dash pod, & an edge EVO for my buddies 03 1500 360ci. (HUGE difference in the 03 1500 by the way, Thanks again Luke!)
INSTALLED!!!
WoW!! I am impressed. the only issues I have are that the Spedo isnt correct anymore, even after entering my tire sizes. is there really not a way to have the truck Spedo read correct? do I really have to use the CTS readout, because it is about 6 MPH off at 70 mph.
Old Feb 19, 2012 | 12:43 AM
wyodiesel92's Avatar
Edge wont reprogram thecomputer to compensate for tire size. So yes on the edge you have to use the readout on the pod
Old Feb 19, 2012 | 12:51 AM
01quadcab's Avatar
take your truck to a shop with a good scanner they can adjust the speedo I had mine done
Old Feb 19, 2012 | 10:39 AM
UglyTruck's Avatar
I can do it with the Hypertech. It allows you to adjust for tire size without flashing any other programming. will the adjustment of the speedo output affect any of the other parameters that the edge calculates?
Old Feb 19, 2012 | 10:48 AM
01quadcab's Avatar
no. but speed on edge will be off unless u tell it speedo was recalibrated for ur tires.
Old Feb 19, 2012 | 12:47 PM
UglyTruck's Avatar
Its way off after telling it now, so that doesnt bother me too much. I was just wondering if after reflashing the spedo calibration with the Hypertech I will then just need to tell the edge that it is "Stock Tire size" or if I will need to enter in the new tire size.
Old Feb 19, 2012 | 07:11 PM
01quadcab's Avatar
stock as it will not try to adjust anything
carid
Diesel Bombers Sponsors
11
May 21, 2015 09:57 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
