HELP
Old Feb 17, 2012 | 05:55 PM
larryz's Avatar
Default HELP
first diesel. I'm clueless.... 01 7.3 won't start. Ran a little rough for a bit (figured because the cold weather) now won't start. Replaced fuel filter and started right up. Ran great for 2 days. Now won't start again. Noticed dripping off of turbo also. The truck is an 01 and has 110k on it. This is my first diesel and I guess I'm in for an education. Any help would be appreciated. Thank you
Old Feb 18, 2012 | 04:20 PM
leakin 12 valve's Avatar
not sure how the 7.3s are set up but im sure there is a fuel shut off you could check that i know it was bad in my truck now i use a choke cable to turn it on and off now. its a electrical switch that opens and shuts the fuel flow it can really effect the way they run to. good luck
