another banks turbo question
Old Feb 17, 2012 | 11:06 AM
83camo's Avatar
Default another banks turbo question
i recently bought a nonwastegated banks kit turbo y pipe and all exhuast and a spare6.9 motor for $400.. the turbo has no side to side shaft play a little up and down if your looking down at the turbo my question is this thing has been sitting for a couple years and the fins look good but it spins kinda hard.. easily spin with your fingers but wont free spin do you think i would be fine just cleaning it or rebuild it somehow? whats the worst that could happen if i install this thing.. thanks
also this truck eats alot of oil i dont think it is blow by ive heard these old 6.9's had shitty valve seals any good ideas on a quick good fix dont feel like completly rebuilding motor and heads?
Old Feb 18, 2012 | 01:09 AM
tyler111991's Avatar
I would avoid any shaft play what so ever in a turbo. And if it is not spinning freely I would buy a rebuild kit. The compressor impeller could fly apart sending shrapnal into the engine if it fails for whatever reason.
Have you done a blow by test? pull the dipstick out with the truck running, or just unscrew the oil cap and see if its smoking or there is a lot of pressure. Some people also do it at night and use a flashlight so they can see the smoke better. Try smelling the exhaust when its running, you should be able to tell if its burning oil
Old Feb 18, 2012 | 04:18 PM
83camo's Avatar
ok where can i buy a rebuild kit iv looked but cant find anything?
Old Feb 19, 2012 | 07:39 AM
DieselCrawler's Avatar
have fun. thats one of the hardest turbos to find parts for. IIRC it is built by mitsubishi.
Old Feb 19, 2012 | 08:00 AM
turbo2332's Avatar
up down is fine, in out is bad. (if the turbo is oriented like it will be on the truck) spray a bit of starting fluid down the oil gally to free things up a bit if its got old oil in it. see if that frees things up any for ya. from what you discribe on the turbo i would be scared to run it at all.
Old Feb 20, 2012 | 03:39 AM
X2 on that. Probably be better off going with a more common turbo, since a rebuild is going to be atleast half of the cost of a new one. Try Ebay, I know there is a guy on there selling "knockoff" versions of HX40s that people have been having good results with on 6.5s
Old Feb 20, 2012 | 11:43 PM
83camo's Avatar
this is just like the kit that i bought is there possibly any other turbo that will bolt onto the back housing of this or anything i can do...and is this the turbo that is actually so hard to get parts for im new to this so i tried making it clear... im hoping you guys were thinking of another one haha
Attached Thumbnails another banks turbo question-kgrhqr-joe6-w-ope-bo98lcgl1-60_12.jpg
Old Feb 21, 2012 | 12:34 AM
hey Im new to 7.3s too haha Ive owned other diesels, all of them IDIs but as far as parts sourcing for these things Im still learning. From what I know about them it was the earlier models of the kit that used the mitsubishi parts. I would try to get a casting number off your turbo and look it up, it should tell you the make/model and with that it will be easier to find a rebuild for, and possibly see what people are using as alternatives. I looked on banks site but they dont tell much info on the model of turbos they offer. But as far as bolting up a different turbo, measure the exhaust flange where it connects to the manifold and see what other turbos match that
Old Feb 21, 2012 | 06:52 PM
Oklahoma diesel's Avatar
Take it to a shop that rebuilds turbos, my old banks was only 800 to have it rebuilt.
Old Feb 22, 2012 | 11:09 AM
83camo's Avatar
the way its sounding is i should find another turbo that i can get parts for that bolts up to my housing
