no throttle response at all
Old Feb 16, 2012 | 09:09 PM
cumminscwby's Avatar
Default no throttle response at all
It's not my truck its my cousins. He's had the truck 2 weeks and babys it. So he decided to wash the engine at the car wash. I got in it afterwards and it cranked up fine but then the throttle went crazy reving up on its own. I shut it off immediately. Cranks it back up and the throttle was dead. It idles fine but that's it. Any ideas? It has efi live but that's all.
Old Feb 17, 2012 | 12:29 AM
2004LB7's Avatar
any codes?
i believe if the voltage/ohms of the accelerator pedal are off it will go into dead throttle/limp mode. try disconnecting the electrical harness connectors and drying them out. WD-40 helps with this.
i don't think the accelerator sensor codes will turn on the CEL, so you'll need to scan for them anyways
Jason
Old Feb 17, 2012 | 08:04 AM
Originally Posted by 2004LB7
any codes?
Jason
That's exactly what we did. Disconnected everything and let it dry out overnight. Runs like a top again. Thanks man for your help
Old Feb 23, 2012 | 12:57 AM
cfarley0210's Avatar
There is a computer under my hood that sais "do not pressure wash" i am not sure what happens if u do but u might have found out. I would try to let stuff dry out and see if it changes anything
Old Mar 29, 2012 | 08:52 AM
kyle_wheelz's Avatar
what did you disconnect and reconnect? cause im having this issue alll the time...i have 3 kids i take to school daily and need my truck bad
any help would be great
jeremiah1
May 19, 2016 04:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
jeremiah1
Jun 18, 2015 05:01 PM
rusty 6.5
Jun 13, 2015 05:45 PM
1stgenswap
Nov 3, 2014 09:45 PM
