Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
2012 3500 Gear Ratio
Old Feb 19, 2012 | 10:22 AM
Gerry R's Avatar
Default 3/4 or one ton
First 5vers have high to very high pin or hitch weights. Second one should NEVER use the empty or ''dry'' weight in any consideration of towing. Third NEVER believe it when the salesman says '' yah that truck is plenty capable of pulling that trailer''. Do your own calculations based on what the MAX weight listed for that trailer, usually found inside one of the cabinets. Then find the maximum weight the truck axle can carry found inside the driver's door jam and I think you'll immediately find a single rear wheel truck axle and tires will have a capacity of about 6-7k lbs which means a 18,000 5ver with a 20% pin weight will add 3600 lbs putting the axle over weight or so close as to give no margine for safety IMO. The truck will pull it, probably without any excessive stress, but braking and handling safety require a dually IMO for that sized 5ver. As an example my dually has about 3600 lbs on the axle with a full load of fuel but empty and is rated for 9350 lbs so an additional 3600-4000 lbs is still well within specs but a single rear wheel axle won't even be close to that. Probably not what you wanted to hear but I believe in towing safely.
Old Feb 19, 2012 | 11:36 AM
sthrnrider's Avatar
Where did the 20% pin weight come from? Strange because my 36' toy hauler has a higher pin weight than the next step up 40' and a lot heavier than mine. According to the specs.
Now I wouldn't pull a 18k camper with a single wheel. With the dually you will have better stability and handling with the 5ver. If your planning on a lot of camping and road use get the dually. Plan on running hilly country get 4:10 gears. I have an 01 dually 3:55 gears. My inlaw has 03 dually 4:10 I can pull my camper and get the same milage with either truck.Both are 2wd trucks. But his will pull a hill better than mine. I have yet to try out my 06 with 3:73. I also don't pull much in the mountains or big hills. Plus the dual lies look better. Lol
Old Feb 19, 2012 | 06:55 PM
Gerry R's Avatar
Default pin weight
First I am not any kind of expert but have pulled two different toy haulers and known many that also have 5vers. All trailers either bumper pull, fifth wheel or gooseneck are designed and balanced different. While one might have a pin weight 17% of total the next may be 25% and that doesn't take into play how we load them, which is amazingly varied. Consider not all have the same size fresh water,grey water or black water tanks nor are they located in the same place. And with toy haulers there is the size and location of the fueling station. Also think about the placement or location of the axles, which greatly affects the pin weight for a 5ver, gooseneck or bumper pull. Then there are toy haulers that tend to be front heavy varying by what we load and where we tie it down. That may help explain the difference in pin weights for similarly sized trailers.
Old Feb 21, 2012 | 06:42 PM
sthrnrider's Avatar
Fuel economy is going to depend on your right foot. You will notice better fuel in town with 4.10 than 3.73 again depending on your foot. You will notice better fuel unloaded with 3.73 on the highway. Loaded I would say your going to be about even. I have an 01 dually 3.55 auto I get 20mpg on the highway at 70mph loaded 15k toy hauler I get around 11. My in-laws 03 dually 4.10 auto gets 16-17mpg highway at 70mph loaded with same toy hauler 12mpg. I have pulled with both trucks I run around 70mph when traffic allows me with the toy hauler. My 01 seems alot happier at 70-75. The 03 seems happy all around. If I had to choose I'd get 4.10. Now I have an 06 dually mega with 3.73 I have yet to pull with it but I will have this input in April when I get back home.
Old Feb 21, 2012 | 06:44 PM
sthrnrider's Avatar
In my opinion i like the 5ver better than the bumper pull. Don't know why but i do.
Old Feb 21, 2012 | 06:54 PM
hydroshok's Avatar
I vote for the dually. The 3.73 gears in my 07 pulled fine with 20k. I had the G56 6spd though. I drove a 2010 auto 6spd and hated it. Just my .02.
Old Feb 24, 2012 | 02:13 PM
sthrnrider's Avatar
Yeah I have driven an 07 with the 6.7 and 6sp auto and didn't like the 6sp auto at all. Just didn't seem to have the pull
Old Feb 25, 2012 | 12:40 AM
mannblack's Avatar
Unless your current truck is dying why not think of a diesel pusher RV and toad your truck/car or heck, get a small cargo trailer for MC's. Prolly cost the same, last longer and you'd have zero issues going up and down hills and freeways?
Ch
Sent from my DROID RAZR
