driver side brake
so i was pulling in the driveway earlier and my brake pedal went to the floor. i knew my fluid must have been low and my brake pad on that side is prety worn. well i looed out the door and noticed my tire was wet, and obviously i knew it was brake fluid and thats why it was low. but i cant see where its leaking from and really dont feel like pulling the wheel and tire considdering their 38s sitting in my driveway on an incline. i was going to see if anybody would have a suggestion
I can almost guarantee that you will have to replace the caliper on your driver's side (unless you split a brake line). I have had this happen. You will have to pull the wheel and caliper off. Look at the piston inside the caliper and see how far it is extended. The boot may be worn and/or cracked which could cause the leakage.
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
pro graphic solutions
Feb 10, 2015 03:48 PM
