mpg's
Old Feb 10, 2012 | 08:03 PM
Wirtzy's Avatar
Default mpg's
I see different people on here saying they get 20 mpgs. How or whats it take to get that kinda millage? and where are you getting that kinda millage, town or freeway. And im saying actually checking it and not reading it in those on boards that are never accurate, if you would have one... I left my truck on millage mode with the juice and it didnt help one bit so was trying to figure out if theres something else or better. any help would be great! Thanks
Old Feb 11, 2012 | 01:23 AM
01quadcab's Avatar
well a set of 285 75 16 tires will create less drag as this is whats on mine. full synthetics motor and diffs as the trans and t-case come stock with it. cold air intake and turn your edge up it will get better mileage on 3 if you don't abuse the throttle. right now I am getting 18 and that is country hills driving to redding and back home. highway I can get 20-23 but you gotta cruise it. a good converter and valve body will also help over stock setup
Old Feb 11, 2012 | 07:01 PM
Wirtzy's Avatar
sounds good, ill give that a try. i have 285 on now as it is so ill put the edge up and see what happens. next oil change we will change some other fluids too. thanks.
any idea for who to go with for cold air intake? or would a BHAF work the same?
Old Feb 12, 2012 | 03:22 PM
01quadcab's Avatar
I like the s&b setup their filter flows enough to make 683 on the dyno. I didn't even take off the air filter last time on the rollers
Old Feb 12, 2012 | 09:47 PM
nclark24v's Avatar
20 highway with max mpg quadzilla
Old Feb 14, 2012 | 11:49 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Are looking at the over head screen that tells you what mileage your getting?? Those are usually incorrect. Try hand calculating your MPGs
Old Feb 14, 2012 | 08:05 PM
Wirtzy's Avatar
thats why i had said actually checking it and not looking at the onboards. i know those are always wrong on all different cars ive had and checked, it always off
Old Feb 15, 2012 | 11:23 AM
01quadcab's Avatar
mine are all hand calculated.
Old Feb 15, 2012 | 02:12 PM
davidyack's Avatar
Mine avg's 21. Hot rod vp44, 125hp injectors, 4" exhaust, raggedy k&n intake kit. No tuner right now. Helps that its a 2wd ex cab short bed. 3.55 gear with 275/50/20 nittos. And the nv5600 6 speed
Old Feb 15, 2012 | 06:48 PM
moneyman_09's Avatar
i get 20 give or take depending on season 01 2wd 3.55 quadzilla and intake. high way
