Transfer case help
Old Feb 10, 2012 | 02:51 PM
ThisisDC's Avatar
Default Transfer case help
when i shift into 4-low, i push the troddle down and i dont go anywhere then it grabs and i move foward, then it shifts 3 times before 20mph. is there something wrong with my transfer case or is it my trans slipping? because im about to replace my trans here in a week or so....i drive a 2003 cummins 5.9l HO. no big mods, only an edge ez and cold air intake
Old Feb 10, 2012 | 08:18 PM
Klickster102's Avatar
4 low is a low gear that is why it shifts soo much, the grabbing might just be it engaging because your going past neutral when u shift the transfer case.
Old Feb 10, 2012 | 10:46 PM
NadirPoint's Avatar
Sounds like the linkage needs adjusted to get it properly into gear to start with. Quick shifting in low range is normal. How fast do you expect to go in low range?
Old Feb 11, 2012 | 12:10 AM
ThisisDC's Avatar
i was about to climb a snow bank at school but when i was on the dry pavement it was doing this. and i dunno how fast...25? whenever it redlines
Old Feb 13, 2012 | 05:59 PM
use 4 high nxt time if you wana go faster, and you shouldnt use 4 wheel drive on dry pavement
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
