Eight Failures Of Diesel Engines
Old Feb 7, 2012 | 07:30 PM
Diesel Bombers's Avatar
Staff Reporter
Default Eight Failures Of Diesel Engines
Eight Things Holding Diesel DownDon’t you wish you could get back all that energy you wasted grinding up brake pads?
Eight Failures Of Diesel Engines | Digg It | Add to del.icio.us
More...
Old Feb 7, 2012 | 08:16 PM
RanchhandTCR's Avatar
Those were not failures they were all suggestions...
Old Feb 7, 2012 | 08:24 PM
wildbill's Avatar
Two Engines In One Compartment
The diesel engine combustion system that sits between your framerails was not originally built for a pickup. Instead, our combustion process was intended for stationary power generation, ships, submarines, airplanes, tractors, and other devices, like irrigation pumps, which run at a steady speed. If you look at a vehicle’s normal drive cycle, you’ll notice it looks like the Rocky Mountains: up and down, up and down. A vehicle idling in heavy traffic exaggerates this fact even more. We need at least two engines—a big one and a small one—to better match the peaks and valleys. The small one should be able to capture the big one’s waste heat or run on its own with a separate combustor. This way, a small, clean-burning engine could be used for the vehicle’s onboard power needs. These include electrical accessories, heating, A/C, power steering, brake booster, and a small hydraulic pump for creeping and short trips. The small engine will start the big one and warm it up so it’ll create fewer emissions and create a cozy cab instantly in the winter.
If you want something similar, get one of those hemi engines that cut out cylinders when they're not needed.
Old Feb 7, 2012 | 09:36 PM
when its -30 degrees my truck cuts down to 3 cylinders for a real fast warm up... I dont think they read this section outta Diesel Power.
Old Feb 7, 2012 | 09:42 PM
GuyWithA24Valve's Avatar
When I read that last line of the Two Engines In One Compartment, the words pony motor come to mind. Caterpillar had it right all along
Old Feb 7, 2012 | 10:29 PM
LORDDiESEL's Avatar
because they're crap and they don't work. I have the hemi in my jeep and when you use your SCT tuner to turn off the MDS, your MPG goes up.
Old Feb 7, 2012 | 11:35 PM
Thats what I was thinkin too! HAHAHAHAHA!!!! Only time I see a pony motor now is when the amish use implements and their horses. I still wonder why the Amish stoped where they did...
Old Feb 18, 2012 | 08:15 PM
farmerdude's Avatar
BULLS%$T!!!! we had a 1950 somethin' model grader and it f'n SUCKED!!!
PONY motors SUCK, that is why CAT went to 24v starters!
Last edited by farmerdude; Feb 18, 2012 at 08:15 PM. Reason: Automerged Doublepost
Old Feb 23, 2012 | 03:39 AM
Eddiebuntain's Avatar
Default haha
Yeah, our Powerjoke company trucks often turn into seven or six cylinder motors, but it doesn't seem to help fuel econ
Old Feb 23, 2012 | 09:04 AM
But, look at how much longer the older Cat diesels have lasted compared to the newer ones (70s on up). And it's all thanks to the pony motors. They made sure there was oil pressure and warmed up the coolant before the diesel fired up.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Aug 22, 2015 12:27 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Feb 23, 2015 06:20 PM
wolfnexus
Nov 4, 2014 10:04 PM
