Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Tranny cooler line leak
Old Feb 7, 2012 | 05:47 PM
HeavyChevyDMAX's Avatar
Default Tranny cooler line leak
anyones tranny cooler lines leakin? just looked under the truck and saw a few drops coming from the fitting.
Old Feb 8, 2012 | 12:08 AM
BriteWhiteRam's Avatar
i bet every single one of these trucks leaks when it gets cold when you have the stock cooler lines on
I've had mine replaced with heavy duty hydraulic lines with good fittings and crimps, no leaks yet
Old Feb 8, 2012 | 06:55 AM
Budgreen's Avatar
where does it leak from? side etc..
just noticed yesterday my pass side frame rail had fluid all over it and some small drops on the ground, looks like from in betwen tranny and tcase? it was messy so i wiped it off and will check later, what might I be geting into?
Old Feb 9, 2012 | 11:55 PM
they are a PAIN to get at and change, the old ones might be easier to cut out and get new ones made at any place that makes hydraulic lines
Old Feb 11, 2012 | 09:30 AM
yea mines leaking from the fitting just behind the bumper. It seems to leak more when its warm rather than cold, i guess the fluid is a little thinner? idk if thats possible
how much do those tranny line cost?
Old Feb 11, 2012 | 10:00 AM
from Gm they are expensive
this is the Kit I got, but Im sure if you could probably get them made up by a local hose maker for a little cheaper
06-09 chevy silverado duramax and 8.1 liter allison transmission cooler hoses | eBay
Old Feb 12, 2012 | 05:45 PM
bubba3m's Avatar
I got the OEM's from GM Parts Direct 2 years ago for $80.00 for all three shipped to my door. I installed them and haven't had a problem since (knock on wood). It is a common problem on these trucks.
Old Feb 18, 2012 | 10:11 AM
cbrew2001's Avatar
Yep..I just noticed mine leaking also a couple days ago and was going to track the leak back to see where it was coming from when I changed my Idler and pittman arm next week.. Now I can be relieved its probably not nothing major and probably just leaking at the fitting like everyone elses here are doing...
Old Mar 26, 2012 | 09:45 PM
Duramax07's Avatar
Yeah i just noticed mine was leaking no more then a month ago. Mine is also leaking on the passanger side right behind the bumper.
I have a few links here which kit looks to be the best?....
1.Transmission Cooler Line Repair Kit - LBZ / LMM
2.Trans Line Repair Kit : All Season Diesel Performance, Your Duramax diesel performance headquarters by Tony Burkhard owner of the Dirty Hooker
3.Allison 1000 Transmission Cooler Line Repair Kit
Any opinions on which is the best kit let me know.... Thanks
Old May 2, 2012 | 01:11 PM
jevanb's Avatar
had mine replaced before the 36 month up at 80k now no problems
