oil leak
Old Feb 4, 2012 | 07:46 PM
codycatract's Avatar
Default oil leak
i have a 97 powerstroke 160k 3rd owner very well takin care of but there is this oil leak i can not find and it comes above starter so starter is always wet (passangerside). ive heard somthing about a fuel rail or somthing, does anyone have an idea its leaking higher then the starter, thanks.
Old Feb 4, 2012 | 08:17 PM
fordornothing's Avatar
check the valve cover bolts.
Old Feb 12, 2012 | 03:09 PM
bowietrucking's Avatar
check your intake valley for fuel leaking. i had lift pump leaking, the sensor in the back of the fuel filter housing, and the dang fuel/water shutoff all leaking at one time!!! had a heck of a mess, ran down the back of the intake and down the block on the starter and tranny pan. hope this helps!
Old Feb 12, 2012 | 03:23 PM
97t444e's Avatar
sounds like a VC gasket
go look at the exhaust manifold and see if there is oil on it
Old Feb 13, 2012 | 07:27 PM
thanks for the help i guess i coulda figures that out i just heard it can be something harder to deal with
Old Feb 14, 2012 | 09:26 PM
kctyphoon's Avatar
$10 bucks says its the o ring for the oil dipstick on the pan. it is rite above the starter, and is KNOWN for leaking. look over the starter- if you see the entry point in the pan covered with oil.. then there ya go.
visit dieselorings.com guy sells a complete kit to repair that. be carefull if you try to fix that on your own..
Old Feb 17, 2012 | 07:57 PM
superdutyman97's Avatar
There's also a threaded plug in the back of the heads. It's 1/2" or 3/8" drive and if it's passenger side you'll have to take the downpipe loose from the turbo to access it. Mine leaked like crazy because the o ring on the plug had deteriorated. It's a dealer item only and it's about $10.00, maybe less. It may not be, but it sounds a lot like the problem I was having. Good luck with it!
cummins Pride
Sep 28, 2015 12:11 PM
BKID
Jul 25, 2015 07:59 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
