Regeneration questions.
Old Feb 4, 2012 | 02:05 PM
5280jeff's Avatar
Default Regeneration questions.
I`m new to diesel motors and have purchased a 2007 2500 with a 6.7l. The regeneration process with the DPF is something I need to learn about. I have several questions any help would be greatly appreciated.
1. Can a certain amount of highway driving without a load allow the regen process to work?
2. Will warming up the truck at idle on cold mornings cause the DPF to fail?
3. If my driving habits won"t allow for the regen process to work properly I"m considering a Smarty Jr DPF delete with a straight pipe. Is this a simple process that can be switched back to stock for yearly emission testing? If so can anyone give a quick tutorial or a link to one?
Old Feb 5, 2012 | 09:29 AM
baddodges's Avatar
If you go to you tube search for dpf removal on a dodge.before I deleted mine I would have to drive it on the hwy.for about 20min for regeneration process.I bought a smarty jr.with dpf delete program and a delete stick.that process took about 20min to install I also did egr cooler delete that was a little more complicated. But you can probly get away leaving yours on.Thoroughbred diesel. Has great prices and can get you lined out on what you need.
Old Feb 5, 2012 | 12:18 PM
00' Quad Cab's Avatar
I would seriously look at deleting the EGR system as well as the DPF.
You have no idea how much crap (carbon,soot,etc.) you are pumping through that engine.
IMHO I don't think we will see the same kind of longevity out of the 6.7 engine with full emissions package as we will out of the older non-EGR engines.
Old Feb 5, 2012 | 12:47 PM
5280jeff's Avatar
Thanks for the help gentlemen. The biggest problem I'm facing is that I have to register this truck where yearly emissions inspections and testing are required. Once I do these deletes how hard is it to get the truck back to stock and running properly to pass an emission test? Returning everything to stock and then having a bunch of codes and a cel could be a yearly pain in the butt. Has anyone returned their truck to stock for warranty work or emission testing?
Old Feb 5, 2012 | 05:44 PM
coors_man_2005's Avatar
if i were u i would get the smarty like your thinking get the delete pipe the delete pipe is really simple swap it will bolt up where the dpf bolts and slip into your factory tail pipe just like the dpf did and just block off the egr so it stays in place but cant flow and it will remain to look factory and would be ez to install/ remove
Old Feb 5, 2012 | 09:21 PM
5280jeff's Avatar
Thanks Coors. I'm trying to find the easiest solution while keeping as close to stock as possible. Emissions laws in Denver are a pain. When I combined a tempermental exhaust system with Denvers emission laws and being newbie diesel owner I found myself with a ton of questions. Can you guys help with some suggestions on how to easily block the egr flow without removing the egr itself? Thanks again!
Old Feb 5, 2012 | 10:12 PM
6.7 Cummins EGR delete kit | eBay
heres a link on ebay for a kit to block off your egr you dnt really need the to plates that bolt into place just use the round peice put it in the crossover tube and clamp it back together i have one at home i would give you but im in louisiana and wont be home for a while
Cummins JR Smarty Junior DPF Delete Kit with DPF Delete Pipe - 07-09 Dodge 6.7L | eBay
here is all the stuff you need
Old Feb 5, 2012 | 10:26 PM
We can beat the price on that dpf delete kit.
Luke
Old Feb 6, 2012 | 11:49 PM
5280jeff's Avatar
Thanks guys you have all been a big help. One last question, am I going to get enough smoke to attract attention from the police?
Old Feb 7, 2012 | 06:09 AM
baddodges's Avatar
You wont get hardly any smoke unless you really put your food into it.
