fass 95 platinum and edge comp
Old Feb 2, 2012 | 09:41 PM
ebbtide357's Avatar
Default fass 95 platinum and edge comp
is the fass 95 enough with the edge comp and tapped vp?also getting ready to do some new injectors any recomendations daily driver tow the the boat a little thats it looking for mpgs and power when i want it
Old Feb 2, 2012 | 09:43 PM
TTcummins99's Avatar
i would go with a 150gph just to make sure the pump gets its fuel you need to baby the VP44 but if you get a fuel pressure gauge and make sure you don't drop below 10 psi you should be fine
Old Feb 2, 2012 | 10:00 PM
RAW's Avatar
RAW
01'QuadCab ran his truck over 600hp on a 95 without any problems. If I remember correctly, the only reason he swapped it out was for the extra filtration capabilities.
Old Feb 2, 2012 | 10:47 PM
95gph would work great for you.
Luke
Old Feb 3, 2012 | 12:33 PM
01quadcab's Avatar
yes and only reason I switched was getting a 2nd vp truck and putting the fass 95 on it and getting a 150 since I had to buy a pump anyway. But the 95 held 15psi all the way down the track.
