1997 7.3 powerstroke
Old Jan 25, 2012 | 01:27 PM
jacked7.3's Avatar
Default 1997 7.3 powerstroke
i have a 97 powerstroke with soon to be dp-tuner. but i have a cold air intake straight pipe, 9in lift, 35in tires. i was wondering what all upgrades i can do to add pwer but keep my motor from blowing up! thanks
Old Jan 25, 2012 | 01:51 PM
MossBack's Avatar
Your motor is fine to 500 HP its the transmission that blows up. I am not sure which transmission you have but get a bts if its auto or a southbend clutch for the 5 'r. Then upgrade the motor.
Search around and do all of your maintenance to the truck before modifying.
sent from my rooted Evo android 2.3.7 using tapatalk. and not a opod
Old Jan 25, 2012 | 03:03 PM
joebob3093's Avatar
Moderator
You can do anything you want. It's all in the tuning and they way you drive.
Old Jan 25, 2012 | 07:24 PM
95powersmoker's Avatar
Also involves having deep pockets and including supporting mods into your power plant. Not just power mods...
Old Jan 26, 2012 | 11:42 AM
jacked7.3's Avatar
ok thanks for the feedback, but could you name some mods? i want to get 100hp injectors, and a 17* HPOP, can someone tell me if the new HPOP is nesessary? also what upgrades vwould i need to support the injectors? i know these are stupids questions... but this is my first diesel. thanks for your help!
Old Jan 26, 2012 | 12:29 PM
joebob3093's Avatar
Moderator
First you need to figure out what these "100 horse" injectors are.
Old Jan 26, 2012 | 12:44 PM
Search around the 7.3 forum for some injector info. Id link it but Im on my phone. Don't know anything about 100hp injectors... Supporting mod will include fuel system, turbo, hpop, intercooler... What are your goals for the truck and approximate budget?
Old Jan 26, 2012 | 01:06 PM
jacked7.3's Avatar
well i just would like to do things slowly, because money is short but i im not sure what i should do next? do you have anything in mind?
Old Jan 26, 2012 | 01:55 PM
Exhaust intake gauges chip. Then drive it. Forget about the rest because it becomes nothing but a money pit after that...
Old Jan 26, 2012 | 02:00 PM
twinboys's Avatar
Stay away from (xx horsepower) injectors. You will have no way of knowing what you are getting and therefore, you won't be able to tune for them (and they won't tell you). You and your tuner will want to know the capacity and nozzle size. Capacity is measured in CC's and nozzle size wil be % over stock. See a reputable injector site like Rosewood. His site will explain what you want to know.
