Pacbrake PRXB Installed
Old Jan 24, 2012 | 07:10 PM
NadirPoint's Avatar
Default Pacbrake PRXB Installed
Finished installing a Pacbrake PRXB direct-mount on the '07 today. Did a little running around afterward to get some first impressions and I am VERY impressed. Just 2 wires plugged into the ECM integrates it seamlessly with the transmission control. I found myself letting off the throttle way too early everywhere I stopped. Seems like it's running in tow-haul all the time now. Very nice setup - high quality switch and solenoid. Install was probably a 5 on the 1-to-10 difficulty scale, so just about anyone should be able to accomplish it, no problem. I deviated from the instructions a little by mounting the control relay inside under the dash and tapping my switched 12V from a source in there.
If you are considering one, I'd highly recommend it. Looking forward to seeing how it helps cold warm-up next time I have to drive it to work on a cold morning.
Sep 22, 2015 02:20 PM
|WYG|SS
Aug 7, 2015 04:52 AM
Nu2cummins
Jun 13, 2015 07:01 PM
tbreddiesel
Thoroughbred Diesel
May 4, 2015 09:32 AM
