Questions about Smarty levels
Old Jan 22, 2012 | 03:46 PM
skav's Avatar
Default Questions about Smarty levels
I have a smarty stacked w a power puck, but haven't really played with the smarty settings. I connected it today, and found that the smarty was set to level 2. I loaded level 8 and noticed that it is much more responsive now, and smokes a bit more off the line.
Can someone explain watch the different levels on the smarty do? I understand that the even numbers have no timing, and are safe for stacking. What is the catcher, mild catcher and soft catcher? I'm thinking about removing the pp and getting an adreniline w pulse. How would this compare to what I have now?
Thanks,
Sean
I just loaded the REVO software on my smarty. What is the difference between the standard software and the REVO?
Old Jan 23, 2012 | 06:07 PM
94dizzyram's Avatar
Do you have a fuel pressure gauge. If not I would recommend one and an upgraded lift pump. I have been doing similar research. I found a lot of info on the smarty from some of the vendors websites. The adrenalin will tap your ip and give you much better mid and high rpm power.
Old Jan 23, 2012 | 08:40 PM
skav's Avatar
I have an II. Hot rod 44 fed by a FASS 150. Do you mind posting links to the info you found? I haven't come across anything besides what I found at MADS.
My fuel pressure at idle is 25psi. Just cruising it sits at about 21-22psi. If I'm hard in the pedal, it drops to around 19psi.
Mar 20, 2015 08:20 AM
05cumminsCA
8
Feb 3, 2015 09:29 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
