air bag light?
Old Jan 21, 2012 | 12:20 PM
firefighter5's Avatar
Default air bag light?
My air bag light started coming on and off the other day. Yesterday it came on and has stayed on everytime I ve driven it. I have a ts 6pos chip. Does anyone know if I need to remove it before scanning and clearing codes? I don t want to mess it up. Also does anyone know if there is a common cause for it to come on in these trucks? Thanks
Old Jan 21, 2012 | 01:09 PM
fordornothing's Avatar
you shouldn't need to remove the chip to scan for codes. if you do remove it, remember, put the keys in your pocket.
Old Jan 22, 2012 | 09:53 PM
OceanDiesel's Avatar
It may simply be the seat belt connector, my wife's has been on for over a year
Old Jan 23, 2012 | 01:39 AM
Xraytheo's Avatar
ya x2 on the seatbelt. they have explosive pre tensioners that cinch the belt tight when airbags deploy. little cylinder thing with a cable attached to the buckle. make sure you disable airbag system before you start messin with those. i always disconnect the batteries and turn a bunch of stuff on but i might be doing it wrong. also the clockspring behind the steering wheel might have an open circuit. it is a coil of flatwire that allows you to turn the steering wheel and make contact for the steering wheel electronics. check to see if your horn and cruise buttons all still work. they could all still work and the clockspring could be bad but often they stop workin too. kind of expensive so make sure it is bad if you replace it.
Old Jan 31, 2012 | 08:41 PM
Sorry it has taken so long to check this. I ve been busy prepping for driver school. Thanks for the help though. I ll get on it and see what i can come up with.
Old Feb 1, 2012 | 08:05 AM
CMCA Swartzkrautheim's Avatar
If not seat belt maybe the clock spring in steering wheel if u got cruise make sure it works if not suspect the clock spring
Old Feb 6, 2012 | 08:30 PM
Thanks for all the help. I have no OD or cruise now either. Next time I get some down time at the station I ll take it apart and see what i can figure out
But if anyone has any cautions or pointers that would help. Thanks
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
carid
Apr 15, 2015 07:29 AM
moneypitk5
Feb 12, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
