tapping the pump wire
Old Jan 18, 2012 | 01:59 PM
Boondockers's Avatar
Default tapping the pump wire
I,ve heard alot of bad things from tapping the pump wires. Is it going to damage my vp if I get a programmer that taps the pump wire. Already have a MP Powerplay with a set of 75hp sticks 4 inch exhaust and airdog fuel pump. 5 speed with valair clutch. Was looking to stack with the MP Poweplay I,ve go on the truck now. What would be a good unit to do that with and what kind of hp gains could I expect to see. Thanks
Old Jan 18, 2012 | 02:35 PM
MillerBoyzDiesel's Avatar
do you mean the ts mvp? either way if youre wanting to keep it and stack it youd probably be stacking with a smarty or some other brand of flash tuner. The tapping of the pump wire would be from using a adrenaline or edge comp, etc. I dont think youd wana stack those with the ts. Both would be using the map sensor at the same time.
Old Jan 19, 2012 | 04:31 AM
yes it is a TS MVP I was old that I,d not be able to stack this with a smarty. I guess with the TS I need a tunner that I can do more fuel only. Or should I consider vp pump work instead of a tunner Thanks
Old Jan 19, 2012 | 07:33 AM
nah u can use smarty just dnt add timing with smarty let the mvp take care of timing and use smarty to add fuel only
Old Jan 19, 2012 | 02:09 PM
for the money the smarty cost do you think its worth the hp gains that I'll get? Have any idea what that would be as far as ponies from adding a smarty? Thank you for the help
Old Jan 19, 2012 | 02:50 PM
01quadcab's Avatar
what does the ts add? sounds like you may be better off with a comp box and taping the pump wire
Old Jan 19, 2012 | 03:20 PM
ts claims 100 horse. smarty claims up to 230 I think. Smarty gives you alot of options, they are great programmers.
Old Jan 19, 2012 | 04:16 PM
No 230hp on a VP truck.... more like 65hp
Luke
Old Jan 19, 2012 | 04:25 PM
65 sounds like smarty jr., but I agree the 230 aint right, stock smarty for cr dont even come close to that high. I dont know where that came from
Old Jan 19, 2012 | 05:28 PM
There isn't a Smarty Jr for the VP44 trucks.
Luke
