need help
Old Jan 17, 2012 | 08:08 PM
CUTNGRS's Avatar
Default need help
My brother has a 2006 f250 today he changed the oil on it and on restart it started and right away it made a noice from the turbo and motor locked up and oil came out the air cleaner has this happend to any one els thanks for any help
Old Jan 18, 2012 | 06:39 PM
bobfbigman's Avatar
Never heard of that before, definately sounds like a turbo failure, pull the whole air inlet tube off and see if you can tell if the turbo is damaged.
Old Jan 18, 2012 | 08:54 PM
CUTNGRS's Avatar
ok when the oil got changed they used oil from a hose with a gage on to tell how much oil was put in the gage said 4 gal but it was wrong and over filled the motor so when they tryed to start it bam!!! so not sure what to do now
Old Jan 18, 2012 | 10:01 PM
bobfbigman's Avatar
Did you pull the dipstick to see how high the oil was? I would get a big, did I sayBIG oil drain pan and drain the oil out, should only be 15 quarts, but if were alot more than that it could have hydro locked. Lets drain the oil first and see how much is in there, use a new or spotless drain pan so you can reuse oil. lets see how much oil there is and that will help tell if any major damage could have been done,,, Who put the oil in?? if a shop then they might owe you some $$$
Old Jan 19, 2012 | 06:54 AM
cumminsf150's Avatar
one time in highschool auto tech class some kid who was supposed to be " cool" filled an engine until it was "full" as in coming out the valve cover....
Old Jan 19, 2012 | 08:53 AM
NadirPoint's Avatar
I have an engine stored on a stand "full" of oil.
But that's not recommended for an engine you intend start anytime soon.
Old Jan 19, 2012 | 04:50 PM
bobfbigman's Avatar
Have we drained the oil yet? how much was in there?
