Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
05 2wd f350 powerstroke straight axle conversion help
Old Jan 17, 2012 | 12:30 PM
pushingmy6.0's Avatar
Default 05 2wd f350 powerstroke straight axle conversion help
Just wondering how i should go about it? should i use a dana 60?
Old Jan 18, 2012 | 06:52 PM
fordornothing's Avatar
well do you want leaf springs or coils? the odds are, your frame already has all the holes you will need. now i beleive your year in 4WD has the D60. you might need to change the output spline on the tranny. you will need a different tranny tail cone. obviously a T- case. different rear drive shaft. please do a floor shift for the T- case. it should be a pretty straight forward swap.
Old Jan 18, 2012 | 07:58 PM
yes i wanna do leaf springs an floor shifter..I was thinking it was a pretty straight forward.. but 05 4x4s are coils.. so i could find a 2000 f250 or 350 an take that front end an put it on my truck?
Old Jan 22, 2012 | 06:12 PM
see that's what i'm un sure of. i think the front end of the frame is different. and it might take quite a bit of imaginearing to make it work. i would do coils and a 5 link front end. if it will take alot of work for the leafs to work.
Old Apr 18, 2012 | 08:44 PM
rjjp's Avatar
I know that the frames were different between our farm truck (05 F250 FX4 5.4L) and my buddies 01 F250 4x4 powerstroke.
Main difference was that the frame on the 05 was higher up than the 01, yet the bottom of the rad was lower.
chrispowerstroke09
Oct 10, 2015 12:04 PM
smbenoit_79
Feb 2, 2015 01:35 PM
gyayo2012
Jan 3, 2015 01:21 PM
Machinist
Dec 5, 2014 01:06 AM
Resolute_Welding
94-98 7.3L Performance
Oct 21, 2014 08:22 AM
