pcm question
Old Jan 13, 2012 | 06:24 PM
CrewCab7.3's Avatar
Default pcm question
I have a question about my pcm. The code is SOD4.I found a list of pcm codes and it says my pcm is for a '94, my truck is a '95. The guy I got the truck from said he replaced the PCM once. What's the difference bewteen the PCM for a '94 and '95? The code for the 95 is SOD5. If I had to get a new pcm could I use the SOD5 pcm? I'm just curious in the difference between the two.
Old Jan 13, 2012 | 07:53 PM
twinboys's Avatar
I can tell you that I have swapped them between my 96' and 97' for diagnostic reasons and once so that my old code specific chip could go with it. There was no difference that I could tell. I absolutely cannot say for sure it will be the same for you...for what it's worth.
Old Jan 13, 2012 | 10:33 PM
CrewCab7.3's Avatar
Well the calibration codes and model codes are the same for all the 94 and 95's with manual trans. I'm assuming the guy I bought the truck from put the '94 pcm in my truck when he replaced the original. I went on car-parts.com and typed in my VIN and it gives all the options for pcm's for my truck and some were listed for a '94 and some for a '95. They all were F5TF but the last three letters were different. They were f5tf-btb, f5tf-btc, f5tf-btd, f5tf-bte, and f5tf-btf. Mine is the f5tf-bte and its the only one listed as a '94 pcm.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Dan S
Jun 9, 2015 06:55 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
12valvenation
Jan 26, 2015 12:38 AM
