2001 dodge 2500
Old Jan 10, 2012 | 11:21 PM
01dodge2500's Avatar
Default 2001 dodge 2500
hey im new to this site. I have a 2001 dodge 2500 with 5.9 gasser and lookin to swap to 5.9 12 valve. im looking for help with what all i will need and pointers on stuff ill have to change. i want to swap to diesel for towing and other stuff around the farm. and help will be appreciated thanks!
Attached Thumbnails 2001 dodge 2500-385983_10150457153499856_501099855_8533484_1730441616_n.jpg
Old Jan 11, 2012 | 06:24 AM
deck60's Avatar
to get the ball rolling need to know if it is manual or auto if you are going auto get a 47rh for manual get a nv4500 no electronics to mess with trans cases the nv4500 takes a 29 spline don't remember what the auto is 23?? get make sure you use a 241-243 dhd or 271-273
Old Jan 11, 2012 | 06:48 AM
turbo2332's Avatar
i vote save up and buy a 2500 or 3500 EXPESSIALLY since you stated its a farm truck. the 1500 chassis ISNT up to snuff to hold the cummins for an extendid period of time. there will be bunches of frame modifications needed. the rear end WILL not hold the torque nor will the front. the front suspension isnt strong enough to hold the weight of the diesel. ect ect.
this project can be done and has been done. but not on the cheap and sure as hell not for a work truck pullin farm implements around
my $.02 dont do it
Old Jan 11, 2012 | 07:48 AM
this is a 2500. and it has automatic in it now not sure what i just bought the truck and if i could id like to convert to stick
Old Jan 11, 2012 | 08:59 AM
turbo2332's Avatar
missed the 2500 part. and you can do all of these things. i think the gas 360's are 46re's ??? may be wrong there. a manual tranny swap can be put together cheaper but plan on $3000 ish to go nv4500 $2000ish for the 6bt so just those no extras your looking at $5000 you can buy a whole new truck for that. thats what im getting at.
Old Jan 11, 2012 | 03:56 PM
Well I guess I could stick with the auto cuz I'm sure its the one your talkin about. How hard is it to switch electronics?
Old Jan 11, 2012 | 05:51 PM
turbo2332's Avatar
the auto for the gasser will not hold up to the diesel unless it is the v10 gasser which its not then the gov speeds are different. if you did it you would most likely want to do a 1st or 2nd gen 12v swap so the eletronics would be non existant or very few of them. dont know how it will effect your dash???
Old Jan 11, 2012 | 10:18 PM
i was just talkin to my buddy and his dad just bought a 1st gen 5.9 motor im thinkin about buying. has rotary pump and turned up and plunger is filed for $800 and he has a p-pump for an extra $200
Old Jan 15, 2012 | 09:46 PM
well i found out what im gonna do. i found a 01 that back end is messed up and back of frame is twisted for cheap it has 24v with 47re. while motor and tranny out gonna beef up tranny and tweek on the motor and just swap it in and change wiring harness and guages and fuel tank
John Sutton
Aug 24, 2015 04:12 PM
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
