94 6.5 Running rough
Old Jan 8, 2012 | 02:32 PM
WesTex's Avatar
Question 94 6.5 Running rough
I have a 94 chevrolet dually 6.5, this started yesterday. At first when I started it after work it was idling rough, when I got to the end of the road it would start jumping from 1500-2500 rpms when my foot was off the gas. Then drop to about 1000 when I put my foot on the gas. I shut the truck off and started it back up and went straight to about 6000 rpms and I shut the truck off. I got the truck home and started it avian today and it did the same thing. Any ideas on what the problem could be?
Old Jan 8, 2012 | 02:36 PM
Crazy's Avatar
Is the check engine light on if so what are the codes
Old Jan 8, 2012 | 06:41 PM
WesTex's Avatar
No the check engine light doesn't come on.
Old Jan 10, 2012 | 10:20 AM
WesTex's Avatar
The check engine light did come on yesterday and gave me the code for the pmd. I had just changed it out recently and was still under warranty. So I replaced it again. I also replaced the lift pump recently. It is still doing the same thing though.
Old Jan 10, 2012 | 11:17 AM
Crazy's Avatar
What code are you getting ?. PMD 99% time don't set off a code
Old Jan 10, 2012 | 03:19 PM
WesTex's Avatar
It was 6-3.
Old Jan 10, 2012 | 04:26 PM
Crazy's Avatar
If it code DTC 63 - Accelerator Pedal Position 3 Circuit High
Check the plug at the pedal make it clean and plug in tight and all so check grounds really good
Old Jan 10, 2012 | 09:44 PM
WesTex's Avatar
I cleaned the plug and made sure it was plugged in good. Then I tried starting it and wouldn't crank. I checked the codes again and got 13, 16, & 49. I see that 13 is engine shutoff solenoid circuit fault. 16 is vss buffer fault, & 49 is service throttle soon lamp fault. What should I do to resolve these issues?
Old Jan 15, 2012 | 01:19 PM
urban-burban95's Avatar
I would start with the cheapest repair first. The codes sound relevant to the issues you are having.
Old Jan 18, 2012 | 07:56 PM
WesTex's Avatar
Thanks for the info. I changed the shutoff solenoid. That didn't work. I'm still getting the high rpms when I start it and then it idles down and jumps high to low. I just don't know what would make it do that.
Another thing is service throttl light has come on. Could that be my problem with it reving up like that?
