New to diesel
Old Jan 1, 2012 | 10:11 PM
SikGilley's Avatar
Default New to diesel
Hey guys, so I'm new to diesels all together , never owned one but I've always wanted one, I'm looking at a 2001 ram 2500 4x4, what should I know about diesels before I buy one, not just what to look for when buying but diesels in general.
this is the truck i want to buy
Old Jan 2, 2012 | 05:24 AM
1999stroker's Avatar
Nice truck. Well test drive it see if it "feels" good, no loose steering or slop, check driveshafts for play in the ujoints, can you carfax it? I always check the fluids on a vehicle can tell you alot about vehicle maintenance. Check frame for rust holes if any. Leaks as well from any where.4 wheel drive system along with a/c heat. Hope this helps. Nice looking truck.
Adam
Strokin' Away
Old Jan 2, 2012 | 12:06 PM
chromehound's Avatar
IIRC there was an issue with the "53" blocks in the 24v cracking around the water jacket. Might want to check into that on both the truck and the boards, not saying it happens to every "53" block but I've read enough about it to be concerned if I ever get anoth Cummins. Check to see if it has been modded-look for gauges and stuff. Otherwise drive it and check for obvious things.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
