Phantom kill switch in my steering column
Old Dec 27, 2011 | 10:50 PM
Holdmybeerandwatchthis!'s Avatar
Default Phantom kill switch in my steering column
I believe I have a short or some other electrical issue in my 89 f250 7.3L. The biggest problem is whenever I shift (automatic) from Drive to either Park or Reverse it oftens kills the motor; just like it's turning the key off. While driving, if I hit a bump the radio and heater fan kicks off until which time I wiggle the gear selector and it comes back on. I'm just curious if others have had this problem and what they did to fix it. Thanks.
Old Dec 28, 2011 | 12:23 AM
BACONBITSFORU's Avatar
The killing motor sounds like a TC problem and just stalls the motor. When the motor dies do lights go off? or on?
Old Dec 28, 2011 | 02:18 AM
H.R.D's Avatar
I would be willing to bet your Ignition wire is causing the problem along with some accessory wires. I would take apart the steering column and do some investigating.
Old Dec 28, 2011 | 04:19 PM
DieselCrawler's Avatar
no wires run up the column. down at the bottom of the column under the dash is your ignition switch. there is a rod that goes from the key down to this. check the plug and make sure it isnt loose.
cumminspwr11
12
Oct 17, 2021 03:50 AM
daniel2500
Apr 23, 2015 11:15 AM
IslanderXJ
Dec 17, 2014 04:14 PM
