6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Need Help Bad,
Old Dec 24, 2011 | 01:03 AM
kayakguy7's Avatar
Default Need Help Bad,
I put in some biodiesel into my tank that I did not filter the oil first. I topped off tank while it was running & the fuel line clogged while I was pouring it in. I am not getting fuel into the filter so i am thinking it is plugged at the screen on the sending unit. Can I just siphon off the tank & refill it or do i need to drop the tank? What is the best way to siphon the tank off? It is a 96 silverado 2500. Thank you all in advance
Old Dec 24, 2011 | 01:13 AM
wildbill's Avatar
Only good way is dropping the tank. But I've drilled a hole and soldered a petcock valve to a couple trucks, and they're holding up just fine. I did that so I can drain the tanks if they got water in with the fuel.
Old Dec 25, 2011 | 03:02 AM
kayakguy7's Avatar
Thanks I did just that, got to driving it back, got a few miles down the road & it lost power & died. I had the vapor return hose loose. Could it have gotten loose & made it die like that?
|WYG|SS
Jul 26, 2015 11:18 AM
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
