4wd not engaging in my 2007 dodge 2500 6.7
Old Dec 22, 2011 | 10:49 AM
pitbullth3's Avatar
Default 4wd not engaging in my 2007 dodge 2500 6.7
My 4wd in my truck is not engaging when i turn the **** to either hi or low. It just flashes about 6-8 times and then the flashing 4wd sign goes off. Any help would be appreciated. Dont know if its something simple or a pain in the _. I checked all the fluids and thier fine
Thanks,
Ryan
Old Dec 22, 2011 | 11:02 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
are they any noises of trying to engage in the transfer. the motors on the transfer go bad sometimes. the biggest problem i have seen is the transfer leaks fluid thru the driveshaft and then causes the chain to stretch and fall off inside.
Old Dec 22, 2011 | 02:04 PM
pitbullth3's Avatar
Havent heard any noises. Is the motor easy to replace or is it something i should have a mechanic look at?
Thanks,
Ryan
Old Dec 22, 2011 | 03:07 PM
diesel pap's Avatar
they are easy. my 08 transfer started making noise and popped real loud. i changed the motor thinking it was it but it ended up being a dry transfer leaking and stretching the chain inside the case. sounds like your electric motor is not working maybe.
Sawyerorr
For Sale
Jul 22, 2015 12:53 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
