Cummins in 93 chevy-questions about 4x4
Old Dec 21, 2011 | 08:09 AM
W.B.C's Avatar
Default Cummins in 93 chevy-questions about 4x4
Im probably going to buy a 93 chevy 3500 4x4 from a friend of mine that has no motor in it. i have a 12v cummins motor thats in parts and im wanting to build it from ground up to make around 450-500 hp. im wanting to use a nv4500 tranny and use a billet shaft and dd clutch. im just having a hard time finding out what transfer case i need to purchase that will work good and be tuff enough to handle the hp and torque. I'll be using the 4x4 a lot and maybe sled pull a few times. Surely i dont have to go with a solid axle do i? Hopefully someone on here can give me the answers. Im aware that i will have to re-do my drive-shafts. Im just trying to get my ducks in a row before i start if you all know what i mean. Thanks for any help!
Old Dec 21, 2011 | 08:21 AM
Red_Rattler's Avatar
High Tech Redneck
Yes you'd want a solid axle if it was my truck but you can get away with A nv4500 with a 241 dhd and the the front can be beefed up enough as long as it's not pulling every weekend...
Old Dec 21, 2011 | 10:32 AM
W.B.C's Avatar
what is the 241 dhd? please dont think im crazy but why cant a person leave the front end the way it is and put a straight center-link bar and tie-rod sleeves in like is done on the chevy-duramax trucks that people sled pull? They hold-up good. Is there a diffrence? I know the solid axle would probably be tuffer but i just hate to spend more money and time.
Old Dec 21, 2011 | 03:59 PM
T00lmanii's Avatar
241dhd is the 241 Dodge heavy Duty transfercase. It was used behind the Cummins I know through '95.....At some point they switched to ......mmmm......the 271? I just finished up on a 12v/241dhd/nv4500 into my 97 suburban, and I can tell you that the solid axle swap into it was more time consuming/costly than most of the rest of the conversion. I'm glad i did it though.
Old Dec 21, 2011 | 11:00 PM
andrewmp6's Avatar
If its going to be a street only truck i would leave the ifs if its going off road and used as a truck the ifs needs to go.I do laugh at how gm used the ifs even on a 1ton where ford only uses it on a 1/2 ton anything bigger is still a solid axle.
Old Dec 21, 2011 | 11:26 PM
tiremann9669's Avatar
Apparently you've never looked under the frontend of an F250.
Old Dec 22, 2011 | 03:25 AM
W.B.C's Avatar
[QUOTE=T00lmanii;833897]241dhd is the 241 Dodge heavy Duty transfercase. It was used behind the Cummins I know through '95.....At some point they switched to ......mmmm......the 271? I just finished up on a 12v/241dhd/nv4500 into my 97 suburban, and I can tell you that the solid axle swap into it was more time consuming/costly than most of the rest of the conversion. I'm glad i did it though.[/QUOTE
What model did you get your solid axle out of and does the 4x4 stick in the floor stay in the same spot? I think i'll probably go with the solid after asking around. if i ever get this truck done, its gonna catch a lot of hell and i want it to be as bullet-proof as i can make it. a lot of people brag on the np-205 dodge transfer cases. do you guys know much about those and if they would work? i appreciate all the info so far, im glad i found this site
Old Dec 23, 2011 | 02:20 AM
andrewmp6's Avatar
I know ford used the twin i beams on the f250 from 80-96 but when it became a super duty it has a normal axle in the front now.
Old Dec 25, 2011 | 11:48 AM
W.B.C's Avatar
does a person need to use coil springs or leaf springs when doing a SAS?
Old Dec 25, 2011 | 12:37 PM
deck60's Avatar
Default t case
I have been doing tons of research on t cases I am using a 273 behind my 4500 you will have to change the input shaft and make sure you do the 5th gear fix and machine about .030 off input
input shaft
http://www.allstategear.com/ part # 5086311AA
permanent fifth gear fix
NV4500 Transmission 5th Gear Repair
transfer case id
first digit speed 1=1speed 2=2 speed
second digit is strength of case 7 is stronger than 4
3 digit is how it is shifted 1= manual 3= electric
I used a 273 but made it into a manual
one more thing what side is your front dropping in on drivers or pass the 205 was primarily a pass drop t case and is almost bullet proof it is a solid gear to gear and does produce some noise
