Idling
Old Dec 21, 2011 | 07:30 AM
HillbillyMudTurd's Avatar
Default Idling
WOuld it be bad on my truck to idle for more than 30 min.
Old Dec 21, 2011 | 12:36 PM
BIGHORN08's Avatar
They say it is in the owner's manual, but I say to hell with it. The only thing it's hurting is the DPF. I let mine idle every morning for about that long, and I've never had a problem; not even a DPF % full light They say cold idling is the hardest on the engine because combustion isn't complete and the rings are cold and don't seal 100%.. warm idling is different, but still not necessary and should be avoided. It will also cause cylinder washdown, diluting your oil with fuel. So, I'm gonna be shortening my idle time to maybe 5 minutes tops. Then just drive it easy til I see the temp gauge begin to rise.
Old Dec 21, 2011 | 12:39 PM
MillerBoyzDiesel's Avatar
its not good for the injectors either
Old Dec 21, 2011 | 04:04 PM
Nutty Jeeps's Avatar
manual for my 99 I believe says 15mins tops is what they recommend
Old Dec 23, 2011 | 10:20 PM
cumminscontrol's Avatar
when i used to pull hotshot, id sleep in my truck...id let it idle all night long in winter months..102k on it now, no problems at all
Old Dec 23, 2011 | 10:41 PM
coors_man_2005's Avatar
never heard of idiling hurting a diesel besides the dpf'ed trucks but who the hell needs an exhaust filter
Old Dec 24, 2011 | 12:03 AM
H.R.D's Avatar
Do you guys not set the high idle and exhaust brake on your 6.7s to help them warm up? It shouldn't take 30 mins to warm them up with that stuff on......
Please elaborate on this one cause that makes no sense to me....
Old Dec 24, 2011 | 03:51 AM
BIGHORN08's Avatar
[QUOTE=H.R.D;834673]Do you guys not set the high idle and exhaust brake on your 6.7s to help them warm up? It shouldn't take 30 mins to warm them up with that stuff on......
[color=grey][size=-2]
I'm probably exaggerating on the 30 minutes. Usually I start it up about 30 minutes before I have to be at work. I'll usually leave 15 minutes early to get there on time. The longest I'd say has been 20 minutes tops. And yes I use my EB almost all the time driving.
Old Dec 24, 2011 | 11:34 AM
i use my high idle but i have all the deletes i have let my truck idle for several hours while im traveling and sleeping in the cab with no injector probs
Old Dec 24, 2011 | 01:05 PM
H.R.D's Avatar
[quote=BIGHORN08;834702]
Good deal, just making sure because there are some people that don't know about the high idle.
