Bump pressure in the fuel regulator?
Old Dec 19, 2011 | 11:11 PM
97powerstroker's Avatar
Default Bump pressure in the fuel regulator?
Hey guys i've read some posts that have mentioned bumping the fuel pressure regulator? What does this do? More horsepower? Fuel mileage? Never heard of it, just wondering how to do it and what to expect thanks
Old Dec 20, 2011 | 04:06 PM
justanother92's Avatar
They are referring to the Fuel Pressure Regulator shim, all you do is take apart your FPR and insert a .177Cal. BB behind or in front of the spring. It mainly helps if your lift pump is getting weak or you are using more fuel than stock fuel system can supply. You might check on Ford Truck Enthusiast. com they are really dedicated.
Old Dec 20, 2011 | 05:42 PM
DieselDanBoy's Avatar
ive personally done this with my truck, made a small but nice difference in the low end. saw mileage just increase a tick.
looking from the front of the truck, on the passenger side of the fuel bowl theres a brass 3/4" nut. remove the nut. if a spring does not come out with the nut, take a small pair of needle nose pliers and remove the spring. dip the end of the sping in a little grease (literally just a dab), so theres just enough to hold the bb to the spring. next take a .177 cal bb for a bb gun (prefferably stainless, copper corrodes), put the bb on the end of the spring and insert the spring back in as straight as you can. youll see the spring will seat in almost flush with the edge of the regulator. then reinstall the brass nut
Old Dec 20, 2011 | 06:00 PM
95powersmoker's Avatar
You won't notice anything but the peace of mind that your injectors aren't going to die because of low fuel pressure.
Old Dec 20, 2011 | 06:14 PM
made a difference on mine, just noticable in the first half of the pedal though. overall not much
Old Dec 21, 2011 | 10:12 PM
There are no consequences on doing this? seems kinda Jerry rigged haha
Old Dec 22, 2011 | 07:12 PM
Nope. You can buy a piece through ford or stick a bb in there. Make sure to only do it if you need it. Check your fuel pressure at idle. You want 60-70. I had 40 and now with the shim, about 62.
Old Dec 23, 2011 | 10:24 PM
How do you check your fuel pressure?
Old Dec 23, 2011 | 11:17 PM
fordornothing's Avatar
the schrader valve on the side of the bowl. it looks like a tire valve stem and a tire guage works great! just make sure it goes up high enough. say 80 psi.
Old Dec 23, 2011 | 11:37 PM
Thanks
