Fuel relay Cummins?
Old Dec 12, 2011 | 08:17 PM
HAMMERTIME's Avatar
Question Fuel relay Cummins?
I have found a truck for 99 cummins for sale that i am considering buying for a second truck for work or a sled pull truck. It does not run some sort of fuel issue the owner has contacted cummins and they think it is a fuel relay. No check engine light so i cant check codes. Any ideas does that sound right? or could it be something else? correct me if i am wrong but a relay would be a uber cheap and easy fix.
Old Dec 13, 2011 | 10:20 AM
turbo2332's Avatar
vp44? if it was a cheap fix wouldt he fix it and sell it for more. i put my money on if its a fuel issue the injection and lift pump are faulty.
Old Dec 13, 2011 | 01:05 PM
HAMMERTIME's Avatar
The name I emailed was Delores so chances are she isn't so mechanically inclined someone told me the relay for the A/C is the same so I could drive out there and swap the relays and fire it up besides I would need to see if its the dreaded #53 block like on my truck
Old Dec 13, 2011 | 01:40 PM
turbo2332's Avatar
i know people with 300,000 miles on the 53 series block. and hell ya if its the same relay and it fires up might not be a bad deal.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
