Electric gauge install help needed
Old Dec 11, 2011 | 08:51 AM
ZombieSoldier's Avatar
Default Electric gauge install help needed
I have a set of autometer c2 gauges for my truck that I'm trying to install. Where can I get an electronic sender for the transmission temp gauge? My truck has no sending unit to begin with, and the harness for the gauges has a 2 port female clip on it not a ring connector. Where would it get put into on my e99 4r100?
Old Dec 11, 2011 | 12:10 PM
fordornothing's Avatar
if you look at the tranny on the drivers side, a little bit forward of the linkage just above the pan i believe there is a plug right there. there is one there on my buddies 2000. the guage set didn't come with the temp sender?
Old Dec 11, 2011 | 12:20 PM
No didn't come with the autometer map sensor either for boost
Old Dec 11, 2011 | 12:45 PM
who did you get it from? i would call them and see what they say.
Old Dec 11, 2011 | 12:46 PM
Froa member on the org that is no longer around. They were new never installed still sealed in the box
Old Dec 11, 2011 | 12:56 PM
well if that's the case i would call autometer and see if you can get the sensors from them. do you have the EGT probe?
Old Dec 11, 2011 | 12:57 PM
Yes I got the EGT probe, just not the trans temp sensor, or the map sensor
Old Dec 11, 2011 | 01:06 PM
99stackedpowerstroke's Avatar
Like he said there's a plug just in front of the linkage pull it out and put the sensor in its like a 8mm bolt, I would go to oreillys and see if the gauges are supposed to come with the sensor, and if not they could order u one,
Old Dec 12, 2011 | 08:12 PM
CSIPSD's Avatar
Call Autometer and get the proper sender... They will be the same for the C2 and for the Cobalt...
Old Dec 12, 2011 | 08:14 PM
Thanks. I got ahold of them today and those parts are on the way
Powerstroke36
Sep 21, 2015 08:32 PM
MrCat4974
Mar 23, 2015 11:30 PM
Feb 7, 2015 10:58 AM
Dec 6, 2014 11:00 AM
scottxmorris
Oct 8, 2014 02:14 PM
