fixed leak but still need help
Old Dec 7, 2011 | 01:30 PM
fravelj's Avatar
Default fixed leak but still need help
i found some permanent head gasket and block sealer so i put it in and followed the instructions and the truck wasnt blowing any white smoke. and it wasnt locking the engine up either. i took it out for a run today and its pouring rain out after it got hot it started blowing blue smoke but it was real thin smoke and it did it when i let off the throttle. is this something else or is it leaking again? and could it be the oil cooler? im waiting for it to cool and i cant check the radator to see if i have lost antifreeze and to see if the motor is locked up on not. but what would the thin blue smoke be?
Old Dec 7, 2011 | 04:49 PM
DieselCrawler's Avatar
that stuff wont work for long. our compression is to high, it will push it right out.
Old Dec 7, 2011 | 06:37 PM
fravelj's Avatar
how long? and it says its made for diesels too
what about it be the oil cooler?
Old Dec 7, 2011 | 07:44 PM
nope. oil cooler will not put things into the cyls.
i explained that in your other thread.
Old Dec 8, 2011 | 03:10 PM
hillbilly hell's Avatar
is it your head gaskets if so just get new ones you cant half *** it with a diesel like dc said their is to much compreshion
Old Dec 8, 2011 | 05:21 PM
fravelj's Avatar
its alot of ******* money to do the damn heads around here
Old Dec 8, 2011 | 08:31 PM
well then quit bitchin and run it till she blows. then bitch cause you didnt fix it before. if you do it yourself, headgasket job will run around 600-1000 bucks, depending on if the head needs work.
cummins Pride
Sep 28, 2015 12:11 PM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
