Heater Problems
Old Jan 20, 2008 | 09:50 PM
streetslayer's Avatar
Default Heater Problems
does anyone else have a problem with their heater in the 1st gens??? i havent pulled out the heater core to flush it yet but i have bypassed the vacume valve under the hood and i got a little bit more heat, but otherwise freezing in my truck. i also have the problem that my defrosters on the dash blow very little air when on high.
any input is great
Old Jan 21, 2008 | 07:09 AM
MotorOilMcCall's Avatar
Is it your blower motor working poorly, or does your heat just not get hot? It could be a bunch of different things, plugged core, bad blower motor, bad blend door, low coolant...all sorts of things. Go through and figure out your exact symptoms and hopefully one of us can help you better.
Old Jan 22, 2008 | 02:46 PM
my blower motor works fine when its on vent but when i switch it to defrosters it doesnt blow that much air, my coolant is fine, and i am going to pull the core and back flush it and hopefully that works. it doesnt blow completly cod air, i do get some heat but nothing much
Old Apr 3, 2008 | 11:27 PM
DieselfreakMI's Avatar
check the thermostat
and it could be mode doors in the dash out of adjustment
thermostat could be stuck open or is the engine getting up to temp.
Last edited by DieselfreakMI; Apr 3, 2008 at 11:27 PM. Reason: Automerged Doublepost
Old Apr 4, 2008 | 01:56 PM
nooblet's Avatar
Your heater core could be blocked by stuff also. I pulled a ton of leaves out of that box when I rebuilt my AC system.
Pull your glove box and check all the vacuum lines behind there. If you are getting mixed hot/cold air its because your not making enough vacuum at one or more of those diaphragms to completely close the hot and cold doors. Also check where the vacuum lines plug into the AC controls, then follow the vacuum lines a little ways into the dash and there is another plug to check.
It really sounds like a vacuum problem to me.
Good luck,
Chris
Old Apr 9, 2008 | 11:53 AM
thanks you guts, it my very well be a vacume problem because i am also having problems with my cruise control, it cant keep a constant speed, it surges up and down in rpm's alot, very noticable with straight pipe stacks,
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
ramrunner01
Feb 25, 2015 11:14 PM
Mike H
Jan 25, 2015 10:08 AM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
